Klipsch VS JBL
Username: Cory
Post Number: 20
Im wondering witch one is better and why for future purchases
thank you for your time
Username: Divin11112000
Michigan
Post Number: 10
I purchased Klipsch, I liked the "in your face" sound of the horn. I went with the reference series as opposed to the senergy series, I was looking for a higher end sound. Only way to really decide though is to sit and listen to them both. Your ear is the only one that matters
schouse13
I too went with the Reference Series Klipsch speakers. Klipsch has it packaged as the RB25 system. I matched them with a Marantz SR7500 receiver. So far it's been great. I am still making a few adjustments to the settings. Good luck.
Any way to remedy extreme speaker cabinet resonance due to shipping damage? I'm interested in particleboard repair and sound damping techniques as well as anything that would normally be used with undamaged speakers as an added measure. Thanks.
Username: Cory
Post Number: 25
well 2 inchs around the inside of insalation in the speaker box should help
were is it damaged
Username: Cory
Post Number: 26
I ment 2 inchs of insalation on the inside of the box should help
Most of the damage seems to be around the bottoms from being dropped on the bottom ends. What type of insulation did you have in mind? Thanks.
Username: Cory
Post Number: 30
dont know the grade of it but can be found at homedepo,reno,etc...
for the type you'd have to search around go to google and type in Diy speakers and you should find some stuff if not email me at skodagun@hotmail.com
the number one thing is that it needs to be air tight(don't fill in the port if there is one) if there is a hole you need to fill it with wood glue
Username: Cory
Post Number: 30
