Hooking up 2 channel dvd audio/sacd
rick9000
I know to how to hook up multi channel, but how do I hook up 2 channel only?
Do I go from R/L multichannel out of the universal player to dvd or cd in on the receiver, or do I take the R/L multichannel of the universal to the R/L multichannel in on the receiver??
thanks for any help sorry for the dumb question
Username: Arnold_layne
MadridSpain
Post Number: 288
On my Pioneer DV-565A player either or both alternatives can be used.
The question is not dumb at all. Actually, on my gear the resulting sound is slightly different for each connection. So here you got yourself a listening test...
Cheers
AL
