Extending My Speaker Wire
Username: Midnytestorm
I just obtained a shelf system and was wondering if anyone can any give me some tips on the following-
#1 Extending my speakers wire?
#2 Suggest a site that gives instructions on using quick disconnects?
#3 I have speaker wire with a white stripe on one side. Does that get paired with black or red?
Thanks for the help.
Username: Cory
Post Number: 15
For #3 i got an answer red ill have to look around for the rest
anyone got any "cheap"priced subs? preverably 10-12's please hit me up!
Username: Riches1
Atlanta, GA US
Post Number: 99
Cody:
Check out velodyne at circuit city.
Username: Riches1
Atlanta, GA US
Post Number: 100
check out audioholics.com on how to make home made speaker cables.
