Top of the line reciever
Username: Monkey_man_jack
Post Number: 63
What is the top of the line reciever,and what is the price of it?
Username: Buckcrazy
Post Number: 63
i would say Arcam avr 300/rotel 1067/nad t773 take your pick about 1500-2000 usd depending where u get tham thanks.
Username: Jonmoon
Post Number: 177
Here are some examples:
http://www.audioenz.co.nz/2004/b&k_avr505.shtml
http://www.cnet.com/4505-6466_7-30973740.html?part=ecoustics-cnet
http://www.soundandvisionmag.com/article.asp?section_id=3&article_id=699&page_nu mber=1
http://www.audaud.com/audaud/OCT04/component/comp3.html
http://www.hometheatersound.com/equipment/sunfire_ultimate_receiver.htm
http://www.ultimateavmag.com/avreceivers/1004yamaha/
Post Number: 79
Thanks, those are some nice receivers.
Username: Mitchbd
Post Number: 64
Lexicon just came out with a new receiver. Lexicon is mainly a high-end manufacturer of seperates, but recently rolled out the RV-8. Check it out at
http://www.lexicon.com/products/overview.asp?ID=14
hope that helps.
Username: Mitchbd
Post Number: 65
BTW - the Lexicon is amazing. Expensive, but simply heaven crammed into a metal chassis.
Post Number: 109
SWEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEET!!!! That Lexicon was...there are no words to describe it was, um... "heaven crammed into a metal chassis."
Hey Brad, do you know what the price is? I couldn't find anywhere. Also, do you know what zone 3 is? I assume you can have stereo in 3 rooms instead of 2 but how does that work? Can you listen to 3 seperate things? If soo then this receiver is the king of receivers.
I just wish it had more watts, I saw a different one that was 170 watts rms. Would the 30 watts make adifference? Even if it doesn't it just sounds good when you can say "My stereo is 170 watts rms per channel."
Anyways, thank you for your reply and that link.
Post Number: 110
Although i just compared it to the yamaha link that Jonathan sent me, and WHOAAAAA! check out all of the inputs and outputs on that thing! And it's 9.1! Thats CRAZY!
GeneN
During my search, I came across this Primare SP21 unit that looks quite slick but have no chance to demo it locally. http://www.sumikoaudio.net/primare/products/spa21.htm .
Also go to Primare's own site for hi-rez pics under Amplifiers.
http://www.primare.net
Post Number: 151
It does look slick, but I can't see paying $4,000 for 500 watt amp. that's only 5.1
GeneN
I know what you mean about the price. I'm actually looking for a good stereo receiver myself. Seems there's none made these days with adequate inputs including an on board phono stage and adequate amplification. I guess I could spring for a multichannel receiver with stereo bypass but that's kinda overkill. Any suggestions?
Post Number: 173
Did you look at the Yamaha receiver that Jonathan posted above? That thing has a bazillion inputs and outputs and is 170 watts per channel and is 9.1, that is the receiver that I wan't.
Post Number: 174
Although I'm not sure I see a phono input on the Yamaha, soo I won't be able to use my Turn table, but hey, this receiver is worth it.
Username: Mitchbd
Post Number: 66
Don't be dazzled my the number of inputs that ANY receiver has. It still needs to sound good! For the price that Yammy wants for the Z-9, there are other - better sounding - products out there. I'm not anti-Yamaha, I've owned a lot of their products (and still do) over the years.
Check out the sound for that price. Even in Audio, there is such a thing as overkill. Happy hunting!
