Paradigm vs. Definitive Technology vs. Totems
Username: Thereal_1_
Hello,
I recently upgraded my receiver to the Yamaha RXV-1500 thanks to the feedback on this forum. I'm now thinking of upgrading my main front speakers and have narrowed down to 3 of them based on a budget of about $1,000Cdn ($800US).
My current setup is all Paradigm:
Front: Titants on stands, Rear: Cinema 90, Center: CC-170, Sub: PDR-10
I was planning to go with Paradigm Monitor 5/7 but decided to spent a little more to get a higher end product. Which of the following speakers would offer me the best value for the bucks and or be the most suited for my setup? I have listened to them all at the show rooms and have mixed reviews. They are:
- Paradigm Reference Studio 40 ($1,000 Cdn)
- Definitive Technology PM 500 ($950 Cdn)
- Totem Accousitc Arro ($1,100 Cdn)
If there are any other speakers in the same class should consider, please let me know.
Thank-you all in advance.
Brad
Username: Cornelius
Post Number: 83
Ohm Acoustics Microwalsh Tall. I auditioned all of the above but I like the Ohms better by a large margin. They are a little more expensive, but I found the investment worth it.
