HELP!!!LYRA-JUKEBOX RD2825/2840!!
Username: Alainamarie
N/a, N/a United State...
Help Please!
When I plugged it in, nothing happened. It says to let it charge for 4 hours for full use and 30 minutes for minimum to no use but nothing has happened. It has been plugged in for an hour or more. PLEASE HELP! THIS WAS MY BIG CHRISTMAS GIFT!
Username: K0ss
Im having this same problem, if anyone knows how to fix this please reply and let us know!
Thanks...
K0SS
BJ
Mine won't turn on either and I don't know what's going on? Help!!!!!!!!!!
card54
Have you tried the reset switch accessible through the small hole in the left side of the case? I have a non-functioning power switch (probably due to the bath the unit took :-() but the reset button usually wakes the unit up.
Username: Jesuspunk25
Post Number: 29
I would recommend resetting it, I just got one of these and it powered up immediately so if resetting it doesn't work I would contact rca about it.
mine won't connect with my pc. it on it running but it says theres no plug in connected
