Yamaha RX-V1500 (or) Harman Kardon AVR 630 ??
jboyle
For $700 budget, which is the better receiver overall ? All you inputs are welcome. Which one do you prefer ? Thanks.
dowdy
What are you going to use this receiver for. For music i prefer the HK. I think it has a warmer sound than the Yamaha. HT is probably a toss up, but the Yamaha might be a better choice. What kind of speakers are you matching this w/?
Username: Heff
Post Number: 127
someone on fatwallet talked about the h/k avr-630 going for $500 at fry's. seems like a good $$$ if you can get it.
