JBL Northridge, Paradigm Performance series or Definitive Technology Studiomonitors. HELP!!!
Username: Turbogti
St. Andrew, N/a Jamaica
I'm so confused about which set of speakers to purchase.
I know you guys say thatJBL's are bright, but can you explain to me what you mean by "bright"
You guys apparently like paradigm, but i can't find where you guy review the JBL studio Series speakers, i ask because i'm getting a good deal on them.
I've heard the def tech speakers on a simple Sony reciever with the 1250 Watt Supercube and boy does it sound good.
What do you guys reccommend?
Bright is kind of a controversial term... Usually it means that the speakers don't roll off the highs.
Paradigms are great and JBL's aren't bad either. What kind of a deal are you getting?
