Using 2 receivers to push 8 speakers...How... anyone???
Sundog
I'm using a Luxman R-117 to drive 4 speakers and would like to use my yamaha to drive another 4 using the same signal.
Current set up is "pre amp out" of the Luxman to the "main in" on the Yamaha.
This works, but there is no volume control on the Yamaha, the Luxman volume controls all eight speakers.
Does anyone know a configuration that would allow independent volume control and full utilization of both amps?
Thanks in advance.
