New member Username: James_sPost Number: 1 Registered: 02-2004 | I have a very respectable home system, Onkyo TX-sr700 amp, Paradigm monitor 90P's, Klipsch RC3, Energy Veritas V2.1, and a 8" 10o watt Jamo sub. All I need now is some cable to do it justice. I've mostly been looking into Monster M series cable, this will run me approx. $1500 cdn. I was wondering if anyone had any suggestions of other cable to look at, or stay away from, thank you |
Anonymous | Audioquest MIT there are a lot of others |
Bronze Member Username: James_sPost Number: 13 Registered: 02-2004 | thanks, I've heard of both, but don't know where to get them... do you have to order them on line? or can you pick them up at your local son store? How much do they cost/perform in comparisom to monster cable? |
Silver Member Username: Project6Post Number: 192 Registered: 12-2003 | here is a good article to read upon before embarking on the old cable quest http://audioholics.com/techtips/audioprinciples/cables.htm cheers |
Silver Member Username: Project6Post Number: 193 Registered: 12-2003 | and here's another one http://2eyespy.tripod.com/myaudioandhometheaterhomepage/id3.html |
Bronze Member Username: James_sPost Number: 23 Registered: 02-2004 | Thnaks for the links, so they pretty well said that speaker wire is speaker wire... I kind of find that slightly hard to believe, I do agree however that you don't need $10,000 cable to make your stereo sound good, I do however think that you can't cheap out on wire and get the radioshack garbage. well, thank you for the valuable information, however....the quest continues |
