I am looking for recommendations on receivers for 4 ohm speakers. Currently I have two Polk SDA-2 speakers that are 4 ohm, and i plan on adding two Polk LSI surround speakers (which are also 4 ohm) and a Polk LSI center channel (also 4 ohm) to make it surround sound. My question is which receivers would be able to drive the 4 ohm speakers without having problems. My budget is in the sub $1000 range.
Damn great speakers.. Had a set of SDA's back in the late 80's.. sure wish Polk didn't slack off in the 90's.. although the their LSi series seems to have them back on the right track again.. I drove my old SDA's with Yamaha seperates back then Yamaha were a great company also but now I would look towards NAD T763 or T773 is you could swing it.. Rotel and Outlaw are also good choices with 4ohm... but your really going to be bumping the $1000 barrier with all, hey if you want the easy way our I can buy those SDA's off you for a couple hundred LOL.. Good luck in your hunt Tim..
