Bronze Member Username: SinkdrainPost Number: 92 Registered: Aug-04 | Is there a difference beween these two subs? |
Gold Member Username: Project6Post Number: 2146 Registered: Dec-03 | According to them the CHT series is"(230V Markets Only - Not Available in the Americas)" |
Bronze Member Username: SinkdrainPost Number: 95 Registered: Aug-04 | So basically they are the same subwoofer with a different name? |
Gold Member Username: Project6Post Number: 2166 Registered: Dec-03 | It looks that way. |
Anonymous | CHT is better I think technical spec and sound. CHT is also available in America. |
Bronze Member Username: Touche6784Post Number: 61 Registered: Nov-04 | dont buy the vx10. how is the CHT not available in the US? its being sold in a bunch of stores online in the US. here is one based in NJ http://www.electronics-expo.com/cat_detail.jsp?a=audio&st=search&d=69&s=Powered% 20Subwoofers i would go for the CHT series. i believe that 8" one was compared with other larger subs and out performed them. plus it has more power. |
Gold Member Username: Project6Post Number: 2205 Registered: Dec-03 | Christopher Lee, I'm just basing this info on the Velodyne website, I figured they would know better, since it is, after all, their product. Hence, the quotation marks, indicating that I am just quoting out of their site. Do you have the CHT subwoofer? How is it compared to the VX10? |
Bronze Member Username: PitburgerPost Number: 25 Registered: Nov-04 | I just got the Velo DLS 3750 R, very good sound and the remote is great. |
Bronze Member Username: Touche6784Post Number: 62 Registered: Nov-04 | yea i see your point. no i dont have the CHT. i was thinking of buying one. i ended up with the VRP 1000. im pretty happy with it. |
