New member Username: SkinnnybPost Number: 1 Registered: Dec-04 | i'm having a tough time deciding. currently looking at: velodyne splI-1000, hsu vtf-3 mk2, paradigm pw-2200 and definitive supercube I. i'm leaning toward the velodyne or the hsu but wondering if anyone has advice or experience in the matter??? |
Silver Member Username: KanoPost Number: 205 Registered: Oct-04 | All good subs, SVS should also be considered. http://www.svsubwoofers.com/subs_pb10_isd.htm this sub is definitely worth the money IMO at $429. |
Gold Member Username: Project6Post Number: 2147 Registered: Dec-03 | Out of your available selection, I will go with the HSU, velodyne is next. |
New member Username: SkinnnybPost Number: 2 Registered: Dec-04 | berny, i'm interested in why you would reccomend the HSU over the velodyne? |
Gold Member Username: Project6Post Number: 2153 Registered: Dec-03 | I feel that it is more accurate whne it came to bass notes, i.e., bass guitar actually sounds like a base guitar. Don't get me wrong, the Velodyne is excellent. It is a personal thing. cheers |
Bronze Member Username: Look4sunPost Number: 24 Registered: Sep-04 | I heard the velodyne is good. But if you look at the specs and material use in their sub, you will notice they are build from "reinforced paper cone" - something like the BOSE (?) |
Bronze Member Username: SinkdrainPost Number: 96 Registered: Aug-04 | Is there anything else in Velodyne's price range that produces "bass guitar" notes that sounds like a "bass guitar?" Or is Velodyne at the top of the list. I see that HSU runs a few hundred dollars more than Velodyne. |
Gold Member Username: Project6Post Number: 2173 Registered: Dec-03 | I wouldn't worry too much about the reinforced paper cone material. They use that because it is less prone to warping during low passages in the source material. You need the proper amount of stiffness on subwoofers unlike polypropelyne cones which is more prone to flexing. sinkdraiN, What is keeping you from getting the HSU? |
New member Username: SkinnnybPost Number: 3 Registered: Dec-04 | nothing...i got it. just set it up today...sounds awesome. thanks for the advice, it made dropping the cash and going with the HSU a whole lot easier. |
