stevie d Unregistered guest | can anyone recomend speakers for my system the receiver is a nad 753. I have the subwoofer covered a velodyne vrp 1200b. also my budget is around $1000 |
Bronze Member Username: EarfulPost Number: 20 Registered: Dec-04 | Are you looking for just two front speakers? |
stevie d Unregistered guest | no I need mains, A center, and surrounds I know the budget is not too much but thats what i have for now |
Gold Member Username: Project6Post Number: 2138 Registered: Dec-03 | Look at the Ascend Acoustics cbm 170 all around...these would be perfect within your budget! http://www.ascendacoustics.com/pages/products/speakers/cbm170/cbm170.html |
Bronze Member Username: MaroonmikeDixie, USA Post Number: 37 Registered: May-04 | I would also check out PSB speakers. The new Image series is excellent. www.dmc-electronics.com |
New member Username: NuckParkhill, Ontario Canada Post Number: 6 Registered: Dec-04 | no doubt, you should check out psb. good advise from Maroon. I have never been disappointed in mine. They do seem to suck up a lot of power... |
stevie d Unregistered guest | thanks for the info on the psb's. Could you recomend a specifc center and mains. Also what do you think of the bi-polars for surrounds. once again thanks for the recomendations |
