Lowerend line's Quality?
Username: Dloweman
Post Number: 21
Just thought I would start a link to see if anyone has really spent time with the lower lines of Yamaha, and or denon. I keep reading that the yammie 1500/2500 and the denon 2805/3805 are pretty great, but can anyone let me know just how much difference is between these units and the lower models like the 650/750 and 1905/2105? I just can't afford the higher end models and was wondering what peoples thoughts are on these models. Thanks for your input!
Derek
Username: Kano
Post Number: 184
Huge difference, if given a choice for one or the other I would definitely go with Denon. Yamaha's RX-V line is good, but the lower end stuff is lacking.
Username: Riches1
Atlanta, GA US
Post Number: 75
I agree with Kano. The lower end yamahas are not as good as the lower end Denons. The Denon 1804 was named as an Editor's choice in Sound and Vision.
I heard a difference between the Denon 2805 and 3805. But, you will make some sort of concession at every price point.
