Bronze Member Username: AmirPost Number: 31 Registered: Jul-04 | my cd player is guilty in the producing of very bad and big trible from my JBL loud speaker(the best loudspeaker i have ever known ). the cd player that i have now is very ancient - LENCO LCD 700. however, after i found the problem, i have 2 options to take in order to gather my ideal HIFI: options 1: buy the azur 640c cdplayer and stay with the the AZUR 640A. options2: buy the azur 640c cdplayer and replace the 640a with NAD c352. which of the 2 combination will be the best choice for hearing rap,clasic,pop,jazz,dance,trance,rock musics..etc. and by the time also to connect a DVD player. i heard that the NAD c352 is preducing a little accurate sound than the cambridge audio 640A it is true? thank you for the help, Amir |
Silver Member Username: EdisonGlendale, CA US Post Number: 595 Registered: Dec-03 | You might want to hear music hall cd25 for more money - you can get a used one at www.audiogon.com It sounds better than azur 640c. If you are still not satisfied with the sound, you might want to add a Puccini integrated amp off www.audiogon.com It will beat the NAD c352. Buying used, you can get more quality for the same money, and if you don't like it, you can sell them back not losing much money on audiogon. |
