McIntosh MR74 & MR78
Username: Ghiacabriolet
NC
Post Number: 530
It's my understanding the MR78 is considered a classic tuner. Assuming it is "better" than the MR74, what makes it so? Would the MR74 be considered a good tuner or is it something to avoid?
Wilson PIckett
The MR78 was a later model of the series, so it is sometimes more desired. It is all solid state, as is the MR74. The MR71 is considered the "best-sounding" of the series, being the last to use tubes.
Need to Register?
Forgot Password?
Enable HTML code in message
