Silver Member Username: FryguyNova Scotia Canada Post Number: 392 Registered: Jun-04 | This is a NEW and promising technology to advance speaker design into the 21 century. http://www.tymphany.com/technology.htm Quote: "In a dramatic departure from conventional cone loudspeakers that displace air across a single diaphragm, the patent-pending Tymphany LAT technology displaces air using a linear array of multiple smaller diaphragms. The result is a much more efficient loudspeaker geometry. Highly scalable, Tymphany LAT technology can replicate a wide range of low and high frequencies-from 20Hz to above 4KHz-to deliver the best home theater sound experience. Tymphany LAT technology enables higher quality sound in space-sensitive consumer appliances such as flat panel TVs, automotive audio systems, home theatre systems, portable pro audio speakers, external personal computer speakers and architectural sound systems. Efficient Form Factor - Fits into rectangular spaces more efficiently than traditional cones. High Density Performance - Provides more bass in 1/3 the transducer space compared to a comparable transducer. Scalable and Stackable - Scales down to 2" and up to 12" in diameter, at any length. Stacks into large clusters for even more power. Vibration Free - Opposing end motors cancel out structural vibration. Transducer will not shake, and will not transmit structure-born vibrations to critical circuitry. Design Ease - Compatible with existing electroacoustic transducer design tools and processes-works with vented box, transmission line, infinite baffle, and sealed enclosures. Low Distortion - The balanced drive design cancels out harmonic distortion, resulting in distortion components that are significantly lower than in conventional drivers. Light Weight - Significantly lighter than traditional transducers with comparable output. " It's about time that someone decided to reduce the size of the diaphragms and arrange them in that way. The problem with a single large diaphragm on a speaker is that the sound becomes directional as the frequency rises. This becomes very apparent with drivers over 12". I can't wait to see more of this technology in the future and see where it takes us with innovative products. |
Silver Member Username: FryguyNova Scotia Canada Post Number: 393 Registered: Jun-04 | Here is a nice picture of the LAT Speaker. |
