I strongly suggest to go with used equipment here. It's just not possible to get a good system for $1k. At the same time you can get very good used items in this budget.
Here is an example of the system you can get for this money: - B&W 602 s2 ($400) - Rotel RCD-971 ($350) - Rotel RA-971 ($250)
P.S. I DO NOT suggest exactly this system - it just to help you understand what is the price level you can afford
