Speaker stands on a TV stand?
edster922
How would putting bookshelf speakers (very small pair of Mordaunt Short MS05s) on top of a 16" speaker stand work if it's placed on top of a TV stand?
These are the speaker stands:
http://www.amazon.com/exec/obidos/tg/detail/-/B0002O00T0
I'm concerned about vibrations, since I thought that speaker stands are usually designed to go on the floor. I'd much prefer to have the stands go on the TV stand for space and aesthetic reasons since my TV stand is so wide.
Username: Project6
Post Number: 2016
If you are going to place the speaker stands, use shorter ones. Ideally the speakers should be at ear level when at the listening position. You shouldn't experience a lot of vibrations from bookshelves.
