New member Username: JazzmanIstanbulTURKEY Post Number: 7 Registered: Nov-04 | Hello guys, i am building a new HT in my house 60% music 40% movies i was pretty much set on the speaker choice but somebody talked me out of it. Ý was set on buying the Quad L series 12L & 11L's + the L center, but a friend of mine talked me out of it he is getting the distributorship of Kef Speakers in Turkey and he told me wait. he is probably going to suggest me the Kef Q7 for the fronts the Q9center along with Q1 for the rear am i doing the right thing on postponing my buy which one would you favor i, really would appreciate the help. Best Regards Kerim |
Silver Member Username: LandrovalPost Number: 973 Registered: Feb-04 | Depends on the price. The KEF Q-series is nowhere near the quality of the Quad L's. The Q's have good uniformity in multichannel, but they also have low build quality and the sound is not great. |
New member Username: JazzmanIstanbulTURKEY Post Number: 8 Registered: Nov-04 | Thanks landroval well the price will be similr to the quad's i assume thus i will get a good deal on both them since i know the distirbutor of both brands in turkey. One of the other issue is the size of my living room my living room is a perfect rectangle around 40m2 my listening area however will be around 20m2 sourrounded by 3 walls and an open side leading to the other half of the living room where the dining table is, the same guy who told me to wait for the Kef's kinda said that the quad's might not be strong enough for the space is that true ? From what i can understand you seem to favor the Quad's over the Kef.? is that true ? |
Silver Member Username: Frank_abelaBerkshire UK Post Number: 216 Registered: Sep-04 | Kerim If he's a friend it might be worth waiting and comparing the two makes. If you can't compare, I'd agree with landroval and choose the Quads over the Kefs, for much the same reasons. Regards, Frank. |
Bronze Member Username: OnimushalordPost Number: 11 Registered: Nov-04 | I would go with the Quads any day but test them out yourself as you'll be the one listening to them day in day out The Quads have a limited Ebony finish out for the standmounts 12/11Ls. Check them out Cheers |
New member Username: JazzmanIstanbulTURKEY Post Number: 9 Registered: Nov-04 | Thanks onimushalord![]() I guess he feels pretty confident about his merchandise. Have you actually seen them on ebony finsih do you know anywhere where i can find a picture ? there was an add on one of the latest What Hi-Fi magazine but it was a small picture and from the front only ? |
Silver Member Username: LandrovalPost Number: 974 Registered: Feb-04 | http://www.wohnraumakustik.de/shop/images/Quad%2011L%20Ebony.jpg |
New member Username: JazzmanIstanbulTURKEY Post Number: 10 Registered: Nov-04 | thanks a lot landroval it looks beautifull |
Qool Unregistered guest | Anyone who knows any review for the Quad 21L besides the one in Goodsound.com |
