Need front speaker recomendation
Username: Gecko
I plan on spending $6-700 a pair for the fronts and would like floor standing speakers as I listen to alot of music on the system.
The receiver is a Denon 1804 so i think I need some warmer sounding suggestions.
I have bookshelf speakers that I will use as surrounds for now and will probably buy a center channel at the same time as the new fronts.
Thanks
Pete
p.s. brands carried by Ultimate Electronics (Audio King) is a plus.
Username: Gecko
Sorry for the double post...
Room size is about 13' x 18' with 10' ceilings and one open wall ("L" shaped room is movie room and office around the corner).
Also the floor is all carpet and there is a pretty big soft couch too.
Username: Elitefan1
Post Number: 162
I don't know anything about Ultimate Electronics but can tell you that the Paradigm Monitor 7 is exactly what you are looking for. They list for $699pr and are very, very nice. They would fill your room and will match as good as possible with your Denon. The matching center lists for $349 I believe.
Username: Browncow
For this price range, I would suggest Athena As-F2. The high range is sweet and the low range is pushing. The mid-range is ok accurate.
Username: Gecko
Post Number: 11
therealelitefan ultimate electronics is at this web address www.ultimateelectronics.com
I liked how these infinitys sounded
pete
Username: Gecko
Post Number: 12
Thanks for the suggestions... Friday I am going to audition the Paradigms, some Monitor Audio Silver 6's and a few others.
The stores website is http://www.stereoland.com/ and the have a pretty extensive selection.
-Pete
