Mp3 from pc to receiver help
puppetmaster
So many option with so little knowledge. I've done the research but still don't know the best way.
I would like to play my music(mp3)from my computer (new dell) to my receiver. It needs to be wireless because they are in different rooms. I would also like to interface it with my TV(new 32'apex).
What do I need? I'm trying to do this with good equipment but on the cheaper side. If that is possible!
Thanks for the help.
Username: Topher
Post Number: 14
You could do it with a Hauppauge MVP, Linksys has a nice looking setup or you could do it with a modded xbox.
I use a modded xbox & love it, but the Hauppauge is cheaper & you can get it to record TV if your computer has a capture card.
puppetmaster
Thanks does anybody have any different ideas. Thanks
