Speakers suggestion....?
Username: Rascalking
Hey.......first of all, I was wondering what people can suggest for a duel computer speaker system.....no bass amp though, i really dont have enough room.......is that "bose companion 2" good?.....and also, i have a laptop computer, and i was wondering if i should first get an external card before getting some speakers.....
Username: Edison
Glendale, CA US
Post Number: 580
You can get m-audio usb device for $80 that sound good. It will improve the sound considerably.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=41784%26item%3D3765961798 %26%26
The Bose is not bad but I wouldn't recommend them - no audiophiles like Bose - it's the power of their advertising - but there are better out there.
You don't have space even under the table for a small sub? Would improve the sound a lot.
You can't get good sound without it.
If not, try to goto a music shop and hear these :
http://www.record-producer.com/recording-studio-equipment/YAMMSP3.cfm
I think the Roland or m-audio might do the trick.
hm.....is all of that really THAT necessary?.....im a huge music fan, but i never listen to rap, so having a crazy booming bass isnt that important to me.....what if i just go with those altec lansings mx5020's......if i did, should i still get that pocket card?
Username: Kano
Post Number: 130
Logitech Z-640 or Z-5500, can't beat those systems for the money.
