Bronze Member Username: XgrizzlyxPost Number: 59 Registered: Jul-04 | I have unshield dual 10" cadence subwoofers in a sealed boxed. It was custom made at a local car audiio place that also was doing home audio. This was back 8 years ago. These woofers are great but just not shielded. Is there away to seal them. My current tv is 36" and it was easy enough to be a good distance away from the tv not to be a problem. but plan on getting a 52 or 61 JVC lcos tv. |
Gold Member Username: Project6Post Number: 1973 Registered: Dec-03 | try using a bucking magnet check this http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=329-210 |
Bronze Member Username: XgrizzlyxPost Number: 62 Registered: Jul-04 | Thanks that should do it!!! And as no more then a buck or so I guess it wouldn't hurt to try :D |
