Bronze Member Username: FlaxtonPost Number: 11 Registered: Nov-04 | Any advantage in upgrading my motor on my rega planar 3 turntable. I HAVE HAD IT REWIRED and had an upgraded counterweight put on it. Thanks. |
Gold Member Username: John_aPost Number: 2563 Registered: Dec-03 | I was wondering about that, too. On another thread here Frank Abela wrote (October 5) "The motor upgrade improves the deck's pitch stability quite a bit. It's also meant to improve noise, although I haven't observed this myself to be honest (whereas I have noticed the pitch stability improvements). The motor upgrade is no joke - it really improves the deck substantially" |
Silver Member Username: Frank_abelaBerkshire UK Post Number: 221 Registered: Sep-04 | Honest, it does! ![]() Regards, Frank. |
Gold Member Username: John_aPost Number: 2572 Registered: Dec-03 | Thanks, Frank. I quoted you not because I doubt you, but because it is the only feedback we have had on this question, and I have no first-hand experience. One cannot audition a motor upgrade! My P3 with original motor and tonearm still beats CD any day. Your opinion counts, and I will consider this recommendation very seriously early next year. |
