Nad c320bee connection to nad l40
Username: Justdog
Hi:
Wondering if I could get some help on the configuration of my system?
The main issue is the integrated amp c320bee functionality.
No sound from a connection to the video in terminals from either dvd or stereo tv.
The hook up is:
Toshiba 20af44 television, nad l40 pre-out to main in on the bee.
The dvd player does not have sound in either the video input or the aux inputs.
The television gives no sound when connected to the bee as well.
The dvd gives sound when connected directly to the aux on the nadl40 and the tv audio out works in the aux on the nadl40 as well.
The issue seems to be focused on the bee.
The inputs are not sending out the input signals from the devices.
The speakers are hooked up 2 for the l40 and 2 for the bee.
The speakers function altogether when the devices are connected to the nadl40.
Unfortunately the nadl40 has only one aux input and that is currently dedicated to the dvd.
The integrated amp has all the connections for all the devices so I must have an issue with the activation of the inputs as they will not pass the signals out and function.
The speakers work excellent the tuner works but the tuner function does not work on the remote, probably config.
The right buttons are pressed for the input device so I know the video in is selected when the dvd or tv is hooked up, still no sound control.
Any suggestions.
Thanks
