This is my 1st post and I appreciate the info. I am buying a large screen HD TV and decided to add a home theater (75% movies/25% music). Installing in 15'x18' family room. Local retailer is offering Denon 3805 w/KEF 2005 system. Have not been able to find much on internet on KEF's, and saw other post mentioning Ord's. Looing at spending around $2,000 for system. Have no install expertise so will need to have installed locally. Suggestions, comments. Thanks
The 3805 is a fine receiver and can easily be weaked for just about any speaker selection. The 3805 can be had for anywhere from $850 to $1,000 depending on if your source and if they are Astock or Bstock.
I am not familiar with the Keff speakers, but I know the for aound $1,000 you can find some speakers that will sound better than one might think. If your dealer will let you, see if you can audition the set either in the shop or at home.
