Multi region / Multi system DVD player
Hi ,
Can any one recommend a good "Multi Region / Multi system DVD players " , prefered with SACD/DVD-A.Which should be able play NTSC & PAL DVD's (DVD-V)and Should be able to produce output in NTSC / PAL.
Username: John_s
Post Number: 8
Anon:
And while we're at it, let's throw in SECAM (France, Eastern bloc/Russia, et.al.). A true Universal Player!
I suspect such a machine doesn't exist, but if anyone makes it, I'll bet it's Panasonic. For some time, theirs was the only 3 system VHS vcr made.
Username: Seamus
I suggest you check out the Pioneer DV-565A (I think it's the DV-563 in the US). Plays SACD & DVD-A. Supports PAL & NTSC (progressive scan only in NTSC), I'm not sure about SECAM. The original as-supplied by Pioneer is not multi-region, but most manufacturers convert and sell the code-free versions. (I think manufacturers cannot supply multi-region players).
Oh, and did I mention it's cheap!
