New member Username: FishccaPost Number: 1 Registered: Nov-04 | Can you help me? my Harman AVR210 will not auto matically select Dolby or DTS when teh DVD is is started. I have compatible Sony with DTS and Dolby and an optical cable. As a matter of fact it will not let me select them as a choice manually... It will if I unplug from the optical, but what good does that do right? Any suggestions please!!!!?? Thanks!! fishcca@hotmail.com |
Gold Member Username: Project6Post Number: 1870 Registered: Dec-03 | check the menu on your dvd player set-up, not the dvd set-up. Check if it is configured to output DTS and Dolby Digital. Check your manual for details. |
New member Username: FishccaPost Number: 2 Registered: Nov-04 | Berny Thanks! Okay, so go to the DVD PLAYER and check out the menu for the output, and make sure I have it set up for the DTS and Dolby output... BTW I am using a Sony SLV-D300P DVD-VCR Combo as the DVD player if any people have insight on that as well. |
New member Username: FishccaPost Number: 3 Registered: Nov-04 | k. Just so you know. Berny is right on! I found the manual for the DVD player online and it says that to use these DTS type functions you need to Enable them first, by default it is OFF! |
Bronze Member Username: SinkdrainPost Number: 62 Registered: Aug-04 | Yea, I had the same problem about a week ago. I wonder how many people don't even know that they are not getting dolby digital and DTS from their dvd player. |
Gold Member Username: Project6Post Number: 1876 Registered: Dec-03 | You'll be surprised. Usually the Dolby Digital is toggled on by default but not DTS. |
New member Username: FishccaPost Number: 4 Registered: Nov-04 | both WERE set to off by default, I switched them on and it AUTO selected DD and DTS depending on my DVD... Thanks Guys! |
Bronze Member Username: SinkdrainPost Number: 65 Registered: Aug-04 | Yea, and mine had DTS set on but Dolby Digital set to off. |
Silver Member Username: KanoPost Number: 113 Registered: Oct-04 | No one mentioned if there's an option between PCS and bittstream, choose bittstream. |
New member Username: FishccaPost Number: 7 Registered: Nov-04 | no bittstream option on mine... Thanks! |
