zenme Unregistered guest | Anyone know how to capture and record the original digital signal of an internet radio stream? Is this signal the same as that coming from the "digital out" on a sound card, or is that a new digital signal recreated from the analog output of the sound card? If it is the orginal digital signal, can it be captured and recorded in the form of an audio file like wav or mp3? Thanks. |
Unregistered guest | Go to code-it.com and purchase their shareware Real Time Recorder. It is inexpensive and IT WORKS GREAT!!! If it comes out of your computer's speakers, it can be recorded in various formats. |
Silver Member Username: EdisonGlendale, CA US Post Number: 589 Registered: Dec-03 | EAC is free - google search for it (Exact Audio Copy) |
zenme Unregistered guest | These won't capture the digital signal that streams into a computer and temporarily resides in a cache file until the sound card processes it into an analog audio signal for listening. Anyone know how to capture that digital component? For example, if it comes in at 64kbps on Windows Player, it's capture implies that one could intercept and retrieve a .wmv digital file that would play back at 64kbps. |
MOD Unregistered guest | Check out Replay music. Works great and automatically tags the files. But I'm not sure of the actual bitrate of the songs |
Anonymous | You may find lots of info about audio/video stream recording at all-streaming-media.com. Here is for example an explanation of how to record AOL streams Find the URL of a Nullsoft video (NSV) stream To find the URL of Nullsoft video stream you may use Project URL Snooper or any other packet sniffer. How to record NSV stream from AOL or Netscape ATM we are not aware of the ability to record NSV streams like the following one Such files can be downloaded, but their protection doesn't allow you to watch them. To download media streams from AOL or Netscape we should find their RealVideo or QuickTime copies first. Getting RealVideo copy and recording it Let's find the RealVideo copy for the following stream: Follow simple steps: Change "_350.nsv&uid=AOL_bla-bla-bla" at the end of the URL onto "_bb8.rm". You will get Change " rtsp://demand1.stream.aol.com/aol/us/aolmusic/aolmusiclive/2004/evanescence/aolm usiclive_evanescence_intro_bb8.rm The latter Real Video stream can be recorded by any video stream recorder supporting Real Video streamed through RTSP protocol. If your URL looks like the following one then Change "_700.nsv" at the end of the URL onto "_bb8.rm". You will get Change " rtsp://demand1.stream.aol.com/aol/us/aolmusic/aolmusiclive/2004/evanescence/aolm usiclive_evanescence_intro_bb8.rm Again we get Real Video streamed through RTSP protocol. Getting QuickTime (QT) copy If you prefer to get a QuickTime copy of the following URL Change "_700.nsv" at the end of the URL onto "_dl.mov". You will get Change " the beginning of the URL onto "http://progressive.stream.aol.com/". You will get http://progressive.stream.aol.com/aol/us/aolmusic/aolmusiclive/2004/evanescence/ aolmusiclive_evanescence_intro_dl.mov |
Anonymous | Re: Anonymous post (Date April-07 2005) How the hell did you work out how to do it? Works a treat! I thank you. M. |
MarteyNoxin Unregistered guest | How do I do that with a song? |
Anonymous | Recording AOL video Harry Connick jr Music video "She" URL http://mp.aol.com/video.index.adp?mxid=1377001&_AOL The nsv explanation, will it work on this, can anyone show me the nsv file? Please let me know if there's ways to save this? Seems it is another type of file maybe? Great if anyone can try to help with this link |
New member Username: IcecreamkidPost Number: 1 Registered: Oct-05 | I got this to work yesterday using URLSnooper2 and CoolBeans. Great Thread Thnx |
hithere Unregistered guest | Thank you for the nsv information |
