Do you mean the 7140 (was 7130 a mistake or typo?)? If so, you will find info here:
http://207.228.230.231/info/NAD_7140.pdf
I found this on the NAD website under the link labelled "Support." If you did mean the 7130, I can't help you as there was nothing there on such a receiver.
I hope this helps!
john rodgers
I have webtv and I cannot get the info because it cannot get into pdf files
