A really stupid speaker wire question?
Username: Sinkdrain
Post Number: 45
I would like to connect my speaker wires without reversing the polarity. However, i can not tell if I did hook it up correctly. My wires run under the floor and are not color coded so I cant tell which was connected to which polarity. I was hoping EZset would check it but it looks like I have to get it right myself. Please advise
Username: Project6
Post Number: 1810
If you don't have a multi-meter/tester you can do this. Connect the speaker wires to the speakers and take off the grills so you can see the cones. Get a small 1.5 dry cell battery and connect (+ and -)it to the other end of the speaker wire only momentarily, a slight tap to the nodes will suffice. Observe the movement of the cones, if it moves outward, you have the polarity correct so look at the + and - side of the battery and you should be set. If the cones suck in, then you have it backwards. Mark the negative wire accordingly with a black permanent marker and do the same for the other end.
Username: Sinkdrain
Post Number: 46
excellent- I'll give that a try!
Username: Sinkdrain
Post Number: 48
BERNY!! Wow, the battery trick worked perfectly. I definately had the polarity crossed because the sound difference is HUGE! I must have gotten lucky with my last receiver.
This makes me wonder how many people buy speakers and after hook up find them dull- only because they crossed the polarity. This was a pretty big difference. Thank you!
J. Vigne
Another way to check polarity is to tune your FM dial to a talk station with a centralized vocal content. When the speakers are in phase the voice will appear centered between the speakers. When the speakers are out of phase the voice will be diffuse and have no center image.
Username: Kano
Post Number: 88
or you can label your speaker wires before you put them through walls or under carpets...
I kid, I kid!
Username: Rkvfire
Vancouver, British Colu... Canada
Post Number: 126
even stupider question.. what is polarty? is that just puttin + to + and - to - ?
Username: Project6
Post Number: 1836
yes
