Whats a good receiver at a reasonable price?
Username: Ckyhigh
I had a really bad receiver. It was part of a home theater package made by sony that was pretty cheap. Not knowing anything about receivers, I hooked some bose 301's to it. Needless to say the receiver blew. Whats a good receiver at a reasonably cheap price, that will power these speakers(and some really crappy sony satelites)?
Username: Riches1
Atlanta, GA US
Post Number: 23
Travis:
Look at the Onkyo 502, usually $299, now on sale at Circuit City and Crutchfield for $269. It was a recommended budget reciever by audioholics.com. I have owned Onkyo in the past. They have a nice smooth sound.
Username: Hokievt
Post Number: 61
You can usually get a refurbished 502 for about $200.
edster922
eCost has the Onkyo 502 for $163 refurb, to be exact. And the next step up, the 601, for $260 refurb.
dustin333
yes i am interested in some opinions on a new receiver. looking for 7.1 receiver setup. My budget is 1300-1500. Any suggestions? Looking for warm clean sound. 70% movies 30% music
Username: Exerciseguy
Brooklyn, NY USA
Post Number: 32
Hifi.com has a Marantz SR4400 for $299.99 With Free S/H. That's the best you can do.
Username: Agimat
Post Number: 57
Dustin333
Try the new ARCAM 250, very warm and clean sound and fits your budget.
dustin333
check postin CANT DECIDE on MESSAGE BOARD
for update where im at that i cant decide
dustin333
Username: Elitefan1
Post Number: 886
Dustin,
Per your description I would add the Elite vsx56[$997 at dynaco.com], the Marantz 7400 or new 7500, the H/K 630 and the NAD 763.
Username: Ckyhigh
i dont know a whole lot about stereo stuff, so i have never heard of marantz or arcam. i will have to check them out. how does marantz compare to yamaha, denon, or hk?
Username: Buckcrazy
Post Number: 28
it just blows them away it it the bomb i would say the best receiver that are recomended here are arcam nad pioneer elite and marantz
