Bronze Member Username: StifaPost Number: 17 Registered: Jun-04 | I wasnt into the amps very much as I bought Marantz 6300 ,but now I am offered used Arcam Alpha 9p wich is a power amp. I thought amps were all the same ...they amplify... So whats the difference between power and integrated amp.? (integrated has volume controls on it and my power amp model is almost without buttons)?? Anyone knows this model 9p? Should I buy it (4 yrs. old)? thanksssssssssss I need answer |
J. Vigne Unregistered guest | You will find the answer to your question and many other mysteries of audio if you will read here: https://www.ecoustics.com/electronics/forum/home-audio/56618.html |
mauimusicman Unregistered guest | Marco, the pre-amp. Volume, tone controls, inputs, etc. Power amps usually have one switch: on/off |
