Looking for suitable speakers for my Rotel RA-02
Username: Joy_in_hifi
India
Hi Everyone,
I am looking for advice on which speakers sound best with the Rotel RA-02.
I have heard them with Wharfedale Diamond 8.4s - sounded good till we turned it up loud when my ears started hurting :-)
My other options which I plan to audition are:
1. Jamo E-570
2. Mission M33 and M34
3. Diamond 9.4
4. Dali 3003
5. Tannoy Fusion 3
Cheers
Joy
Username: Frank_abela
Berkshire UK
Post Number: 165
If you can find them I would suggest:
Acoustic Energy Aegis EVO3 (big floorstander, great value)
B&W DM600 or 601. (The 600 is more musical but the 601 goes deeper.) standmounts
Dynaudio Audience 42 - standmount (but a cracking speaker)
Totem Dreamcatchers - standmount (also a cracking speaker)
Which one to choose would depend on your taste.
India
Thanks! I will add the AE EVO3 and B&Ws to my list as they are available for audition in India.
Joy
Berkshire UK
Post Number: 172
Have fun! Of the two, my preference is the AE.
Regards,
Frank.
Username: Walt_h
CA
Post Number: 39
I would second Frank's recommendation on the Acoustic Energy speakers.
India
Can someone tell me what is the range of speaker impedence and sensitivity that I can choose from to match the Rotel RA 02. For example - all the Wharfedales are 6 ohms and 86 db whereas the Jamos are usually 4 ohms and 90 db sensitivity.
Thanks
My RA-02 is match with Polk Audio Lsi9 4ohms 88db
and sound very good.
