I added a center channel speaker to my 752 over the weekend (previously just had 2 mains), and have begun playing around with various surround modes. So far it sounds great, but I'm mildly baffled by one thing:
When I cycle through the various surround modes, EARS and Enhanced Stereo don't appear... Has this happened to anyone else? I realize I'm probably missing something terribly obvious, but for the moment I'm at a loss.
You may want to check the manual's description of these surround modes. They may require a 5.1 set up. I recall that the enhanced stereo boosts some of the speaker's gains although I don't remember which ones. Also, I once made the mistake of turning on the B speakers and then I couldn't get any of the surround modes. I would guess that this problem is simply a set up problem.
OK this makes sense... As Prologic and DTS Neo:6 are available w/ just 3 channels configured, I assumed EARS would be too, and the manual is unclear on this. Thanks for clearing it up.
This is just another reason to add surrounds sooner rather than later...
Thanks again!
Gr1m
Have you tried changing the setup from 7.1/0 to 5.1/2 in the OSD? When i have mine set at 7.1/0 I can access the Neo:6 but not EARS, but when i switch to 5.1/2 then Neo:6 is gone, but EARS is there. But I do have surround speakers so that may be your problem as well
