Kiss DVD DP 1000 Optical out
Hi there every1
I bought the kiss dvd player. The only why to get surround sound is via the optic out. My problem is my amp has no optic in. My amp only has the (left, right , centre, subwoofer, rear )coax inputs. Can i by some converter that will take the optic from my dvd player and convert it to the normal (left,right,centre...etc) outputs.
Thanks in advance for any advice.
John
Username: Kegger
MICHIGAN
Post Number: 1782
There is but it would cost more then a reciever or dvd player
that has the right connections!
