Best slim speaker set?
Tavish
I am building a projector HT setup and like the idea of having slim speakers wall-mounted to the left and right of my screen (with the center channel on top as well). I know that by choosing slim, wall-mountable speakers I will be sacrificing sound quality. But can anyone out there recommend some slim, attractive, wall mountable speakers that also have decent sound quality? Thanks!
Username: Elitefan1
Post Number: 820
There are more and more of these types of speakers being made all the time and you do not need to sacrifice sound quality. A good example is the Def Tech Mythos series. Not cheap, but very nice. Polk and many others make these also. There was a review of several brands in Sound & Vision a couple months ago and I will try to give you some info on that later when I am nome and can lay my hands on that issue.
Username: Elitefan1
Post Number: 822
The article I am refering to is in the January issue. You can find it in the archive section at soundandvisionmag.com.
Username: Frank_abela
Berkshire UK
Post Number: 151
Or you could consider the new Elac pipes, or the Jamo 355s. Both fine speakers designed to go next to plasma screens on the wall.
Tavish
Great, thanks for the link. Does anyone else out there have any recommendations for a stylish, slim speaker set?
Username: Cornelius
Post Number: 51
Magnepan
Username: Stone
West CoastUSA
Post Number: 109
Magnepan does have some flat wall mounted H/T speakers
Username: Landroval
Post Number: 921
+1 Magnepan.
Epic
The Mod2 Orbs (Orb Audio) look pretty slick next to a thin TV.
Username: Rick_b
New York USA
Post Number: 609
The Maggie MMG's.....................
Tavish
Cool, I checked out the MMG's and they are exactly what I am looking for...very stylish AND affordable. I read up on some reviews and it looks like they perform pretty solidly as well. My only concern now is picking out a receiver to go with these. The FAQ on their website says that the power rating at 4 ohms is the most important thing to look at when picking out a receiver. So I have looked around but haven't been able to find specs on 4 ohm capacities.
Can anyone recommend a good receiver to match this speaker set (4 MMG W's and MMG C center channel)? Also, is it necessary to have a receiver AND an amplifier, or will the receiver sort of perform double duty there (sorry, I am a complete newbie at this stuff)? Thanks in advance!
Username: Stone
West CoastUSA
Post Number: 111
How much you willing to spend? With the money you are saving on speakers, a Carver sunfire or a midrange B&K receiver would drive them and then some.
Tavish
I am not looking for anything too fancy. As long as it can put out 100 watts to each speaker and allow for multiple room output, then it should meet my needs. If I have separate (powered) PC speakers that I run through the receiver, I want it to be able to output on all channels simultaneously. Should I be concerned about the Ohm power rating? Magnepan's site states that the speakers have a 4 ohm impedance, and I'm not really sure what that means or how it affects the receiver I should purchase.
Username: Rick_b
New York USA
Post Number: 610
Tavish,
It is imperative that you select a receiver that will drive a 4 ohm speaker. Make sure it will. BTW, the MMG's not only look stylish, but they sound great too. A definite bargain at the asking price. Cheers!
Username: Noodle
Beaverton, OR USA
Thanks everyone for the input. It looks like I will definitely be going for the Magnepan MMGs. So now it's just a matter of finding the right receiver...
::shuffles off the Receiver forum::
