Hi My brother gave a NAD T743 as an advance Christmas gift. Currently im hooking it to my old DM302 and I think theres a hint of a little harshness and it lacks detail and punch. I would like to upgrade to higher bookshelfs but my brother said there are only four brands available in his place: Paradigm, B&w, Monitor Audio and PSB. For $400(its the only amount he set aside for speakers) or less, please give me your recommendations from these four brands. Thanks.
Check out the Paradigm Mini-Monitor and the MA Bronze B2. Both are excellent but do have different sonic characteristics. Whichever you like better will serve you well. I would probably choose the Paradigm myself.
Thanks elitefan.
But if the budget is increased to $600, would you recommend other models among the four brands?
Those are all great manufacturers. The best would be to listen to them all on the amp you're using. Decide for yourself. None of them should let you down.
