Any of them would be fine. I went from a really cheap RCA cable to AudioQuest and heard a difference. This I attribute to the dismal design of the other cable. The only time you'll hear a difference in sound is if you get a bad cable. Either of the brands listed above will make a decent cable even in their entry lines.
Malecai
My subwoofer will stop playing until I physically disconnect from the amp via the coaxial digital cable and plug back in. Is this a bad cable? This occurs in dvd's, tv and xbox.
