Speakers for SET (13 watt EAR 859)
Username: Raymond
Need help with selection of full range speakers to replace my aging Mordaunt Short Pageant IIs. Problem is my single ended triode is only 13 watts and I would like a forward firing port so I can have them located against the wall....Soliloquys won't work!! Room size is 15X13. I listen to all types of music. Budget undetermined. Any recommendations please????
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 233
Klipsch Cornwall. The room is a bit small for Klipschorns, but if you have good corners on the 15 foot wall, it work just work too.
