Marantz SR7400 with Quad 12L???
Username: Falp
Post Number: 106
I'm pretty much decided on electronics for my brand new and first AV surround system, Marantz SR7400 AV receiver (can get the price of a new SR5500 and is awesome good sounding for a AV Receiver)
and DV6400/6500 player.
70% music/30%movies.
I'm trying to decide on speakers for months....
It's the esthetics, the size, the efficciency or the looks...
I was decided on the MA Silver S2+S1+SLCR but the size of the SLCR won't fit in my furniture... but loved the sound very much with Marantz.
I have listened to Monitor Audio Silver , Wharfedale Evo , B&W 600 , Canton Karat , Visonik Evolution ...
I never put the Quad as an option (esthetics), but he L12 / L11 have a very good finish and look good closed...
Can the L21+L11+Lcenter be a good match for the Sr7400?
Thanx in advance!
Username: Landroval
Post Number: 912
It depends what you like. If you want crystal clear and bright sound then Quad+Marantz is a bad choice, but if want smooth and detailed sound with good bass it's the perfect option.
Username: Falp
Post Number: 107
Why do you say that?
They're both to the warm side?
I like the MA Silver + Marantz combo, it's true...
Username: Landroval
Post Number: 919
Yes, both are on the warm side. But I dont think you should abandon that option just because I said they're warm. It's not a bad thing.
