Speaker help
We just got a new Denon 2803 matched with Denon dvd -910 which we are using with Bose 300 rear speakers. Any ideas for 2 towers and a centre channel speaker to match . Cost less than $2500
Username: Johnnyness
Post Number: 28
hello anon.
pretty bold move to say that you're using Bose speakers on here... do you already have a sub? How big is your room? Do you listen to music or watch movies more? I used to have Bose myself.... but I recently upgraded. You have a lot of options for 2500 bucks.
Username: Edison
Post Number: 328
You can do better than to match Bose speakers for that money. You can still use the Bose for the rears since not much there anyway. You are in for a pleasant surprise when you get your new speakers - if you choose wisely.
Something like these will be an improvement.
http://cgi.audiogon.com/cgi-bin/cl.pl?spkrfull&1079983452&class&3&4&
http://cgi.audiogon.com/cgi-bin/cl.pl?spkrfull&1079842395&class&3&4&
http://cgi.audiogon.com/cgi-bin/cl.pl?spkrfull&1079812584&class&3&4&
http://cgi.audiogon.com/cgi-bin/cl.pl?spkrfull&1079622350&class&3&4&
Before pulling the trigger, I would go slow and read Hifi magazine sights like www.hifichoice.co.uk and www.audioreview.com
and visit a few hifi specialty shops to hear many speakers first.
As you know, take what a salesman saids with a grain of salt. You can chat alive at www.audioasylum.com and ask questions for more advices.
There is a world of good sounds to discover - much better than Bose.
Thanks for the help so far. I had the NHT Super two towers and a center channel, but they got ripped off and are now discontinued. They seemed to be a good match for the Bose although I'm only using the Bose cause I have them and the room is at least 15x15 unfortunately with lots of glass window surfaces. We use the system mostly for movies.
Username: Sticklag
Hit the send button too soon. I was looking at the NTS ST4's with a sc 2 centre channel on line as possible replacements. Any one tried this in a similar situation?
Username: Hawk
Post Number: 88
Ripped:
I have spent a lot of time evaluating the NHT ST-4s and I would recommend them without the slightest hesitation. They are one of the finest towers I have ever heard for under $1K. I have not heard them with the Denon, but I would think they should work fine.
