Bridging a micro system
Username: Dehoogl
Hi all,
I am integrating a sub into my micro system on the cheap and was wondering if my method of bridging is OK. All I have done is simply connected the positive lead oto the positive terminal on the right channel and the negative lead to the negative terminal of the left channel. The stereo has nothing about bridging in the manual. I fthis isn't OK, can you recommend a really easy (or not so easy) way to do it. Any help will be very much appreciated.
