your last 2 postings are confusing, if the wiring is broken between the crossover and the driver, you should be able to replace the wiring and re-solder it. use the original wire if you can recover it, otherwise replace both sides (+/-) with comparable wiring
i was told by some guys that i need to "glue" down my voice coil, why would i need to do this? i don't even know what a voice coil is. never mind why it would need to be glued and finally can i do it myself? thanks
