Will my amp power these subs?
Username: Dustin_9
Greenbrier, Arkansas USA
Post Number: 7
I just bought two Punch series 2 ten inch subs. I have a Rockford Fosgate p2002 amp and i dont know if i can run both the p2's off the amp. Can someone please help me figure out if i will be aight with just the one amp to both. Thanks in advance.
Username: Rh1
Post Number: 330
Dustin...you have posted this question in the Home Audio forum, you might want to try the car audio forum as they will be more knowledgable there
Username: Trracer
Sebec, Maine USA
it says the p2002 is 200w x 1 bridged at 4 ohms, which isn't exactly alot, expecially when u r talking bout pushing 2 subs, and 50w x 2 at 4 ohms is even worse..... it'll surely run them but an upgrade in amps might be in store soon, because if u run the subs too long with a small amp they'll be underpowered and blow, and i don't think u want to be buying new subs anytime soon... it's better to get a huge amp then a small one, u can always turn the gain on the big amp down.
