Goddamn Aiwa
Username: Japput
DublinIreland
I purchased an AIWA NET-MD. Got SonicStage 2 with it.No matter what I do, SonicStage gives an error on reading the goddamn CD. Falls over. Tried re-installing many times. No good. In desperation, I got Realplayer (V10 Free), and that doesn't recognise my MD! Got different device drivers (tried the Realplayer Sony device driver) no good. Hit transfer and after 50% transferred-falls over. Is this as good as it gets? Any ideas?
Username: Japput
DublinIreland
Should have mentioned I'm on Windows XP..
Username: Japput
DublinIreland
Problem solved! The Hotfix for Windows XP has a negative impact on SonicStage.It's patch KB840987 to be exact. Go into Add/Remove programs and remove this patch and all was fine for me. Note Windows XP will try to download this everytime again so you will have keep removing it until a permanent fix is found. I saw this in some other post. Thanks.
i did it, but i still can't transfer my mp3 files to my minidisc.
"Cannot convert the specified song.
SonicStage doesn't support the file format of the song."
i'm so stuck i have a t.v with a video attached to it and i have put a paasscode on it and i have forgotten it... there is a possible 9999 that can be put in but are there any other ways in which to find the passcode out ?? i need help
Need to Register?
Forgot Password?
Enable HTML code in message
