Username: Argento Post Number: 68 Registered: Apr-04
Wednesday, October 20, 2004 - 14:09 GMT I have a doubt about an equipment interconnection. If I want to connect a receiver with pre-outs to an integrated amp or a pre/amp, How should I do the connections between then? Thanks for the help.
Username: Argento Post Number: 70 Registered: Apr-04
Thursday, October 21, 2004 - 02:26 GMT I want to use the equipment for music (the integrated or the pre/amp) and for movies (the receiver) without change connections and using a single pair of main speakers. Which is the right configuration?
Username: Project6 Post Number: 1726 Registered: Dec-03
Thursday, October 21, 2004 - 10:21 GMT You want to use a single pair of speakers with 2 amplifiers??? You still need a switch to go back and forth between the amplifiers/receivers/integrated amps.
Username: Argento Post Number: 71 Registered: Apr-04
Thursday, October 21, 2004 - 15:04 GMT Berny says: You want to use a single pair of speakers with 2 amplifiers??? Yes, that's the idea. Would I connect the mains pre-outs of the receiver to an AUX input of the integrated or pre?
Username: Argento Post Number: 72 Registered: Apr-04
Thursday, October 21, 2004 - 15:06 GMT Of course, the mains speakers should be connected to the integrated or amp.
