HK AVR630 shuts down.
Does anyone know about this problem? - Everytime I turn my receiver on, it would automatically go into standby mode. Bananna plugs are used so there is no short circuit. Anyone else has this problem before?
Anyone...?
Username: Kano
Post Number: 36
Most likely the power supply needs replacing.
First try cleaning it internally with a can of compressed air.
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 143
Does it still shut down with no speakers connected at all?
Username: Cmy330go
I just got a avr630 that also shuts down at random. The other night I tried to isolate it by unplugging something each time it shut off. I finally got down to just the power cord and nothing else and had the volume control all the way down and it still shut off.
Any Ideas????
Username: Dary
Sao Paulo Brazil
Post Number: 25
Try to reset the unit. Ok, ok... you've already done that.
